SailNet Community - View Single Post - Heat Exchanger help
post #3 of Old 05-08-2008
erps
the pointy end is the bow
erps's Avatar
On my Volvo MD17C, the raw water runs through the reverse gear box first and that is a fairly common failure point for obstructions. I would also pull the end caps off the heat exchanger and look for obstructions and I would check for obstructions in the very beginning of the circut, your thru-hull inlet. Over the years with differnet boats, I've experienced some heating problems from each one of those areas, especially in the fall when we get a lot of loose eel grass floating around.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
