SailNet Community - View Single Post - Thinning for Spray
post #2 of Old 05-08-2008
artbyjody
artbyjody's Avatar
Originally Posted by cas8100 View Post
Im about to spray Interlux Epoxy Primecote with their branded spray reducer. I have a gravity fed spray gun for the job but have never sprayed Interlux paint before.
The Interlux website as well as the can has explicit directions on the ratios to use for thinning. Their paints are very ratio biased so do exactly (and with what they recommend) and you will not have any issues. If you try to do it on the cheap and cut the epoxy with other substitutes you will be very unhappy with the results ..
Good luck!
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
