SailNet Community - View Single Post - Heat Exchanger help
post #11 of Old 05-08-2008
artbyjody
artbyjody's Avatar
Have you checked the water strainer? I had the same identical situation, and it ended up being that the water strainer was clogged with algae... (Thanks again David)... it could actually be that simple.
Most water strainer at least for diesels - are very small and under sized resulting the symptoms occurring more heavily. The reason why it is not happening at the dock is that you are not putting any load on the engine and therefore it draws less water...When motoring it draws more and the water strainer when clogged will more readily restrict the flow that is required.... so it may not be the heat exchanger after-all....(I am assuming this was something not looked at)....
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
