Mike, I've never heard of a sticker that wouldn't stick to CLEAN Hypalon. i suspect you don't have Hypalon, or, that something like ArmorAll was used on your dink, in which case nothing will stick to it until you use a solvent to pull off the ArmorAll. If you can get something else (like 3M's "Clear Duct Tape") to stick to the dink, maybe put down a small piece of that and put the sticker on that. It won't be quite as permanent but it shoulod be good enough unless someone peels it off.
