Old 05-09-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
I wouldn't make the beam out of stainless steel. First, a hard edged beam like that up against the hull is going to cause a hard spot where the fiberglass will flex and fatigue. You really don't want to do that as a general rule to fiberglass....especially across the boat.
I would recommend building a bulkhead beam of marine plywood that has been laminated and then glassing it to the hull. It might have to be a bit thicker, but it wouldn't cause a hard spot like the steel beam will. It also won't rust or deteriorate any time soon if the wood is properly fully encapsulated in fiberglass and epoxy.
Another advantage to doing it in marine plywood is that you can do all the fabrication yourself.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
