  #24 (permalink)
Old 05-09-2008
sailaway21 sailaway21 is offline
gadfly
sailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the rough
I've seen reports on ships that otherwise met Det Norske Veritas standards of even ten years ago that had a fire erupt, resulting in significant loss of life, because of the wall covering adhesive used was toxic when burned. There is a lot of stuff out there that, in a fire, becomes a problem.
I've seen more than one crew member even sleep through the General Alarm bell signals on board ship.
Fire on board ship is different. In fires on shore the FD ventilates the building for visibility and firefighter safety. You never ventilate on board ship, in fact, you close the ventilation down first off. Just containing a fire on board ship is a big project, not always achievable.
Those with only a shoreside familiarity with fire and safety should not assume that their knowledge translates to ships. Even most sailors do not know what is involved. The only example I can come up with that might resonate with the sailing community is to imagine if you had some type of oil fire at the base of your companionway. You'll probably end up abandoning ship, especially if it's not caught early or you have no extinguishers accessible from the cockpit. It started out as a small fire but you were unable to fight it as the majority of your fire-fighting gear was kept below. That possiblity is repeated hundreds of times on board a ship. And one should remember that we cannot pick the passengers who will be at risk; they could all be 70 years old or not even speak the same language as the crew. Things get complicated.
Sprinkler systems and the like are not necessarily the answer. The SS Normandy capsized right at the dock in NY after fire broke out on board. And the NYFD was basically responsible. They doused the entire ship with water from on the dock and via fireboat. They literally loaded the decks with water. That water caused free surface effect, resulting in a virtual rise of the ship's center of gravity, and she capsized while still tied to the dock.
Ships used to have wooden lifeboats as well. I'm sure the owners felt they'd paid a lot of money for those boats as well and that their ship was well outfitted by the standards of the day. Those standards have evolved and so we don't have to worry about lifeboats burning up either on board or in a sea of burning oil.
SOLAS regs are signed by all of the signatory countries involved and, if there was controversy over updating those regs, they wouldn't sign on. They are and, at a minimum, pasengers should be glad that they do. And, btw, shipping is one of the most hazardous forms of transportation around. When things go bad, they tend to go very bad indeed.
