It amazes me that they do this.
So often, when I see people working on boats, they make the same mistakes that the manufacturer of the boat made when repairing the boat. Why would you want to do that.
A good example is in one of the recent threads where a hull support in the bilge rusted away because it was made of stainless steel. Why would you want a large chunk of stainless steel in your bilge?
IMHO, it would make far more sense to replace that chunk of stainless with a fiberglass laminate that will not be affected by the water that often is found in the bilge. Also, a steel piece up against the hull, like this piece was, will cause two hard edges that the fiberglass laminate will flex and fatigue against—where a properly installed and designed laminate support will not.
Just because the manufacturer chose to do it a certain way, doesn't always mean that is the right way to do it. Before going about a repair, I think it makes sense to take a look at what other alternatives there are and if any of them make more sense to use.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
