artfuldodger,
my real reason for this fishfinder/sonar is to augment my current depthfinder (only a digital readout of actual depth) with a fishfinder....Here on the Hudson river, we get a really great run of striped bass. The bass tend to follow schools of herring, as well as school themselves...also, they tend to congregate in certain spots with structure. My thoughts are that I could get a fishfinder to help me find herring and stripers, as well as the depths/structures they tend to hang out in. Also, another "depthfinder" that will quell suspicions when I don't trust my true depthfinder....those are my reasons I suppose.
That stated....any reason why an inside the hull transducer wouldn't work out?
I also had another idea........call me crazy......
My bristol has a lazarette in the back where the outboard engine sits, there is an opening in the transom to allow for the outboard to function. The lazarette compartment is sealed from the rest of the boat obviously. Can I drill a hole in the bottom of the lazarette (through the hull and into the river) and install a through hull transducer, as long as I put the hole more than a foot from the lower unit of the outboard?
I envision a certain amount of water pouring through the hole, then stopping, me screwing the thing in, then pumping the water out. There naturally is an inch or two of water sloshing around in there all the time anyway, with barely enough freeboard at the transom (4-6 inches or so) to mount my 15 hp mercury.....
Would I sink my boat doing this? lol
I'll check back in after dinner.
