SailNet Community - View Single Post - Fresh Water System
post #3 of Old 05-11-2008
sailingdog
Either the pump is bad or you've got a leak in the accumulator tank or somewhere else in the pressure side of the system. If it hasn't pumped your fresh water tank dry, then the problem is most likely the pump and not a leak.
sailingdog is offline
