SailNet Community - View Single Post - Fresh Water System
post #4 of Old 05-11-2008
minggat
Heeled over
The spurts and sputters indicate that you are sucking air, which means a leak in the suction side of your system, not the pressure side. I am not saying the problem is not in the pump, but you are introducing air to the system. You don't say if you have a diaphram pump or a vane pump. I can see the problem might well be in a diaphram pump. But a hole in the diaphram that can suck air would also spurt out air or water in the pressure stroke.
minggat is offline
