Thread: Ugly lifelines
Old 05-14-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
If you're going to replace your lifelines... replace them with uncoated stainless steel. The plastic coating traps water against the stainless steel and leads to crevice corrosion, and hides the problem from easy inspection.
Doing it yourself isn't really a big problem, since there are many ways to do it properly and make perfectly safe lifelines. Mechanical fittings, like Norseman, HiMod, StaLok and such will allow you to terminate the ends equally strongly as a swaged fitting, although at some slight price penalty.
If you're new to the Sailnet Forums... please read this POST.
