Thread: head odors
  #36 (permalink)
Old 05-14-2008
Cruisingdad's Avatar
Cruisingdad Cruisingdad is offline
Moderator
Cruisingdad has a spectacular aura aboutCruisingdad has a spectacular aura about
Originally Posted by westerly33 View Post
Thank you CD,
I cannot see pictures but have got product names from the links.
So, adding Cl you simply killing any flora in the tank.
Thanks again.
In my opinion, I think the point of this is not killing what is in the tank, but what is in the intake line. I think that is the source of most smells on the boat.
We also add a chemical treatment, in addition to the tabs.
My opinion is that it is the intake that is the issue on many boats - not the holding tank itself. You get a nice little flora buildup in there too. I have not done a micro study on this, but it seems logical to me that what happens is that you get a colony of microorganisms living in your intake line. THere is little/no air, so as the die and decay, they are being digested by the same anerobic bacteria that would live in your tank in an anerobic environment. Thus, when you pump (especially if you have not used the head in a while), you get a strong sulfur (ie, stink) that is horrid.
THe inlind Cl tabs prevent that from happening. They release in a relatively low concentration. I guess you could probably put vodka or rubbing alcohol in there with the same benefit - just costs more (smile) among other issues.
This option is not a traditional option. I am still reseacrhing the effects of it, which is why I have not written this up in Mainsheet. I very cautiously suggest it.
HOWEVER, 2 years running... and no issues.
Regarding the Cl gas, you would think that if it was truly doing that in sufficient quantities to produce a toxic gas, when you popped the pumpout, you would get a nose full. That has not been the case. Perhaps because of the ventilation outside you do not get it?? I am not sure. I gues if you had a major leak down below, it could become a problem. Of course, with a major head leak down below you would have to abandon ship anyways!! (smile).
Sailnet Moderator
Catalina 400 Technical Editor
