Btrayfors can answer about the antenna question...
As for grounding the unit, I'd recommend brazing/welding a tinned copper lug or tab to the steel frames, not stainless steel, since stainless steel is a poor conductor and has about 30 times the resistance of copper. Then bolt the copper strap to the lug, and you'll have a pretty good ground plane.
Just remember for the radio signal, the wider the copper strap, the better the signal conduction is to a point. I'd think a 1.6 mm x 3" strap would work quite well.
Do not put the copper lug or strap down in the bilge if you have a wet bilge, since they'll effectively turn your boat into a battery. But if you have a wet bilge on steel boat, you got other problems anyways.
Epoxy coating the copper to help protect it is probably not a bad idea.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
