  #21 (permalink)
Old 03-26-2001
h20nut h20nut is offline
h20nut is on a distinguished road
Best Keel for Coastal and Blue Water Cruising
Your comments about Catalinas being pan boats is very misleading. If you would like to join me for a tour of the Catalina plant in Largo, I''d be glad to show you the structrual grid component used in between the hull and inner liner. This is , by far the, difference between Hunter/Beneteau. Why do Catalina owner''s consistintly move up through the product line,30''s 34''s, 38''s.
I would invite comparison for value with any other manufacturer.
Do you have a problem with Yanmar/Universal engines? Charleston spar? Lewmar, Raytheon, Edson,Garhauer, Bomar, Maxwell, Aquasignal,Schaeffer furling. Where did they cut corners with second rate hardware? As far as accessability check out any new boat. Dare to compare.
I like the wing keels although, if not careful rudder damage could occur. ( A problem with any high lift eliptical spade rudder)
