  #34 (permalink)
Old 05-16-2008
JiffyLube's Avatar
JiffyLube JiffyLube is offline
Grasshopper
JiffyLube is on a distinguished road
Originally Posted by camaraderie View Post
Jiffy...A 3 stage charger is an absolute must for AGM's...but I meant more than that.
In order to get the benefit of faster charging times...you must have a system that can deliver MORE amps to the batteries than similar flooded batteries could take. Example...lets take a 400ah battery bank.
If you had flooded batteries you could put 80amps into them during bulk charging (20% of capacity).
With AGM's...you could easily put 160amps into them thus cutting your charging time in half...BUT on the hook you need a 160a charger working off a generator or a 160a alternator that can give that much output in order to realize that benefit. Either way, you need a 3stage charger or regulator along with the additional capacity.
That's why I said charging system rather than just one component of the system.
Cam, thank you for that explanation.
