Old 08-12-2003
mcain mcain is offline
mcain is on a distinguished road
Ice box insulation
The standard "best" insulation is the extruded styrofoam, also known as Dow "Blue Board". Available in lumber yards in various thicknesses and not real expensive. Its a board-like material and can easily be cut or sawn. Also available in a pink variety. This is not the standard white styrofoam that cups are made of--same material, different process.
The pour in foam was commonly used in the past and has good insulating properties, but it should be sealed against moisture. It also is a tremendous mess. It gets on stuff and is very hard to clean up.
