SailNet Community - View Single Post - Engine Dies HELP!!!
post #5 of Old 08-12-2003
windancer1
Engine Dies HELP!!!
All the previous responses are good, being a owner of this engine I have encountered the same problem in the past. What I found was the lift pump diaphram had a small pinhole and allowed air to work into the fuel lines then to the injector(high press. pump). After rebuilding the pump and bleeding the lines the problem was solved.
Hope this helps.
Dave R.
windancer1 is offline
