SailNet Community - View Single Post - Perkins 4.108 shaft rotation
Old 05-20-2008
Slooptattoo's Avatar
Slooptattoo Slooptattoo is offline
Senior Moment
Slooptattoo is on a distinguished road
Rotation
Yes and Yes, check with your local prop shop (the larger the better) and have them do a computer analasis of horsepower and wieght of the boat and desired cruising hull speed to determine if your prop can be used or it just needs to be tweaked. More than likely you will need to have them recondition and repitch your prop. But what do I know, that's just what I would do. Good luck! I am assuming you have an 1 1/4 Shaft?
Mike and Joyce, S/Y "Tattoo"
"There is nothing- absolutely nothing-
half so much worth doing
as simply messing about in boats."
The Wind in the Willows
