SailNet Community - View Single Post - Trying to improve in 2 areas: puffs/gusts & gybing
post #2 of Old 05-20-2008
sailingdog
Merlin-
What kind of boat are you doing this in...what sail controls does it have. Flattening the main sheet, using the main halyard, cunningham, boomvang, outhaul and backstay tensioner are a good way to help depower it and make the boat heel a lot less, using the traveller can also help a good deal.
A lot of getting a smooth gybe is practice and repetition... It would help if you said what kind of boat you're gybing, since some boats have different requirements than others. For instance, a sonar, which often has a self-tacking jib, has less for you to do than a soling would, which usually doesn't have a self-tacking jib...even though the two boats are relatively close is size and setup otherwise. Also, do you have crew or are you talking about learning/practicing all this singlehanded?
sailingdog is offline
