SailNet Community - View Single Post - Trying to improve in 2 areas: puffs/gusts & gybing
post #4 of Old 05-20-2008
nolatom
Upwind, the traveler suggestion may be the best one. Ease the traveler, keep the sheet fairly tight, and you may be less overpowered by the puffs and hence can react a little less with both sheet and helm. Or try easing the traveller in the puffs, see if that keeps the main quieter while still relieving the heeling pressure.
Jibing, I get down to a run, then trim the main to get a minimal "slam" arc; I tend not to cross over too early, stay in the middle and duck, I may steer with my knees, then once the boom rushes over, ease real quick, cross over, and make sure you keep the bow downwind (without re-jibing of course) so you don't round up and broach.
Your jibe routine sounds basically okay, might just need a little tweaking. Lots depends on the type of boat.
After a while, both maneuvers become so instinctive, you have to think hard and replay it in your mind in order to describe it in words.
nolatom is offline
