SailNet Community - View Single Post - Trying to improve in 2 areas: puffs/gusts & gybing
post #7 of Old 05-20-2008
sailingdog
Basically, if you tighten/tension the main halyard, cunningham, outhaul and backstay tensioner, you will flatten the mainsail. The backstay tensioner will also tend to flatten the jib or genoa as well. All of this will help depower the boat quite a bit. Ease the boomvang and tighten the boom brake (if you've got one).
The heavier the winds, the more tension the boombrake line will generally need... this doesn't de-power the sail, but does de-power the boom when you accidentally gybe the boat.
Easing the traveler to windward will help too.
sailingdog is offline
