SailNet Community - View Single Post - Perkins 4.108 shaft rotation
Old 05-20-2008
KeelHaulin's Avatar
KeelHaulin KeelHaulin is offline
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
  1. Quote:
    Originally Posted by capttb View Post
    OK, gotta correct myself, standard engines are called left handed because rotation direction is named by viewing the flywheel. Reverse rotation engines (RH) are rare but do exsist
Correction! RH is a "standard" rotation engine; prop rotates clockwise as viewed from the stern. The LH is an odd rotation usually one engine on powerboats with twin screws.
Also be aware that some transmissions will reverse the rotation of the shaft relative to the engine rotation; so you need to check either the driveshaft while the engine runs or the prop pitch to determine if the driveshaft is LH or RH.
My boat has a 4-108 with a B-W Velvet Drive (1:1 IIRC). The shaft rotation is RH.
