SailNet Community - View Single Post - not enough water outta egzost...
post #1 of Old 05-20-2008 Thread Starter
Unhappy not enough water outta egzost...
I have my Cal 9.2 on dry dock and getting it ready for the season. Last year before we moved to land the engine was not running at %100 towards the end. So I started the engine with a bucket of water this year to see what's up. No water coming out of the back. Checked the water pump and the pump is ok. I removed the hose out form the out side of the pump an there was sufficient water so it's not the water pump. Replaced the thermostat, now there is a bit of water coming from the back but very little and has black tar like stuff in it. I by passed the thermostat with another hose and fed the water directly in to the elbow and I had enough water coming from the back so no clogs in the egzost system however there was some black hardened tar or something in the in part of the thermostat housing that I scraped with a screwdriver. Installed everything back on but still next to nothing of a water. Checked Torreson's site for Universal 5411 which is what I have I think and they say engine zinc are not used in this unit??? Also I don't know if I have a heat exchanger or not. I am thinking of removing the elbow and checking it this week to see if there is any condensation otherwise I am open to any and all suggestions you may give... Thank you....
Also I think the raw water is actually circulating through the engine without a problem....
Thanks again...
sendrom is offline
