SailNet Community - View Single Post - not enough water outta egzost...
post #3 of Old 05-20-2008
CharlieCobra
On the hard
CharlieCobra's Avatar
Egzost huh? Phonetically correct I suppose but IIRC it's exhaust. If you have a heat exchanger, it's likely full of crap or just corroded. If it's just a water muffler it likely the same issue. The tar in the water pump might be some oil tar from an old spill that got sucked into the system. If so, the strainer would be fairly plugged as well.
CharlieCobra is offline
