SailNet Community - View Single Post - Steer with rudder or outboard?
post #13 of Old 05-20-2008 Thread Starter
eMKay
eMKay's Avatar
[QUOTE=timebandit;317451]
Originally Posted by nolatom View Post
Also, how does a solid link between rudder and motor work if, once you're done with the motor, you're going to kick up the outboard to reduce drag, which is what we do on this lightweight boat? Seems to me learning to do both manually is part of the learning curve.
Just disconect the link.
Conecting the two will ensure the rudder does not get eaten by the prop.
The rudder can't touch the prop on my boat, it has a spring loaded mount, the prop doesn't come close to the rudder.. The mount has two lower setting too, one for short shaft, and one for long shaft which is convenient because I have a long shaft now, but just bought a short shaft 4-stroke.
Technician, RCR Yachts Buffalo.
eMKay is offline
