Are you giving it full throttle then settling back? It takes quite a bit of grab from the prop to unfeather...
So in other words you have to give high burst to open - then low throttle and gradually increase to engage it...
And are you properly feathering it according the manufacturer. ON mine the max prop I have to pull it into reverse - some are forward..
It may be more operator related as it gets all confusing as all get out as it is a behavior totally different from a fixed prop...
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
