  #18 (permalink)
Old 05-22-2008
Maine Sail's Avatar
Maine Sail Maine Sail is offline
Maine Sail has a spectacular aura aboutMaine Sail has a spectacular aura aboutMaine Sail has a spectacular aura about
Originally Posted by jjablonowski View Post
I dunno about worst enemies.
Others, like the author of this article http://sailmag.com/boatworks/0408BilgePainting/ think differently.
Sorry but.....!
You CAN'T always believe what you read in magazines and it's no more evident than in the poorly researched and written article you referenced!
Here's a direct quote from Mr. Nielson:
"There’s another reason to protect your bilge with paint. Water standing in a bilge can migrate into the hull laminate. There have been numerous cases of boats coming up with osmotic blistering on the inside, or even with core damage."
No sh&t Sherlock BUT there is NO paint including "Bilge Kote", the paint he referenced in the article, that will prevent osmotic blistering!! The only known products that will reduce or prevent blistering are #1 Polyester Gelcoat (has it's downfalls but works for longer than any paint) #2 Vinylester Gelcoat (much better than polyester) #3 Epoxy barrier coats and epoxy.
Please show me ONE paint, INCLUDING BILGE KOTE, that makes the claim that it prevents blistering as Mr. Nielson eluded to.
We need to stop putting these magazines & their writers up on pedestals! They are often very, very wrong!!
One quick phone call to Interlux will get you these answers:
Is Bilge Kote a barrier coat? = NO
Does Bilge Kote prevent water from getting to the laminate? = NO
Does Bilge Kote prevent chemicals such as gas & oil from getting to the laminate? = NO
Does Bilge Kote prevent odors from penetrating the substrate? = NO
Is Bilge Kote resistant to oil and gas meaning they won't soften it? = More so than many other one part paints.
To prevent osmotic blistering in the bilge what should I use? = A barrier coat (they sell barrier coat BTW)
Are barrier coats impervious to chemicals? = Most but you should still coat it to protect it.
With what product should I coat 2000E to protect it? = Bilge Kote.
But if Bilge Kote is not impervious to chemicals, water and odor how is that protecting the barrier coat? = I don't have a good answer for that.
BTW, Bilge Kote is nothing more than a modified, quick drying one part Polyurethane paint designed for bilges but offers only beautification and zero benefit beyond that....
P.S. Mr. Nielson also admits what I stated about bilge paint although he greatly diminishes how difficult it can be to remove the peeling bilge paint.
"If your bilge has been previously painted, a rotary wire brush mounted on a drill might be the best way to get rid of paint flakes."
______
-Maine Sail
Casco Bay, ME
Boat - CS-36T
Our Sailing Photo Galleries
Poster Formerly Known As - Halekai36
