SailNet Community - View Single Post - Garmin 478 chartplotter
post #2 of Old 05-22-2008
sailingdog
Connect the unit to the computer using the NMEA 0183 serial port, rather than the USB port. Maptech Offshore Navigator Light should have no problems with talking to the GPS then.
You will need the data cable as well as a serial port on your computer, and you'll need to make sure the Garmin is set to transmit in NMEA 0183 mode, which is 4800, 8, n, 1. The default is usually Garmin's proprietary serial protocol, which MapTech's software won't recognize.
sailingdog is offline
