SailNet Community - View Single Post - Spinnaker with sock...
  #11 (permalink)
Old 05-22-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
Originally Posted by vabuckeye View Post
I was going to try with a leader long enough to clear the railings and see how I faired.
That's more or less the idea. A tack line from the stem fitting (where the headstay attaches at the bow) to the tack of the sail would be fine, allowing the foot of the sail to clear the bow pulpit. Better still if you could lead that same line back to the cockpit (through a turning block at the bow), so you could adjust the luff tension easily.
