SailNet Community - View Single Post - Server is SLOW!!!
post #12 of Old 05-23-2008
sailingdog
Idiens-
Go to the start menu and click on "RUN"
Type "CMD" in the dialog box and hit "RETURN"
TYPE "cd C:\windows\system32\drivers\etc\" and hit "RETURN"
Type "attrib -r -s hosts" and hit "RETURN" — This is to remove the read-only and system attribute properties from the file, since you need to edit it.
Type "notepad hosts" and hit "RETURN"
In the Notepad window that then opens, go to the bottom of the file and type "127.0.0.1 youchoose.net"
Save the file and quit Notepad. In the CMD window, type "EXIT" and hit "RETURN"
You will probably have to reboot for the modified hosts file to take effect.
If you type the quotation marks and run into a problem because of it, I will fly out and beat you about the head and shoulders... TYPE ONLY WHAT IS IN THE QUOTES. BTW, you did say dummie's guide to doing this.
sailingdog is offline
