SailNet Community - View Single Post - Pump Float and Three-Way Switch Install
post #10 of Old 05-23-2008 Thread Starter
max-on
1997 Dehler 33
max-on's Avatar
Keep in mind SD the size of my boat, the relatively flat shallow bilge, and that I have yet had a need to use the pump. The bilge area is so shallow that I think water would need to be at the floor before the pump went on, thus, why I have not 'tested' the pump.
The only seacock I leave open is the raw water on the engine from the saildrive, given I have to remove the stairs and cover to access that; an access port is another project.
max-on is offline
