SailNet Community - View Single Post - Pump Float and Three-Way Switch Install
post #11 of Old 05-23-2008
sailingdog
TB-
A lot of bilge pumps were PO installed, and not manufacturer installed, and some PO's ideas of the proper way to do things is less than ideal.
I can think of a few reasons you might want to have a three-way switch instead.
For instance, if you have a maintenance level pump and want to test your emergency bilge pumps and their float switch, it might be nice to be able to shut off the maintenance level pump, which often has the switch installed at a lower height than the higher-volume emergency bilge pumps.
Max-on
You really should close that each time, when you leave the boat, since a hose failure could end up with your boat sitting on the bottom. Me, I still close the seacocks on my boat, and on my boat, if I took all the hoses off of them and opened them up, the boat wouldn't sink...
sailingdog is offline
