SailNet Community - View Single Post - Pump Float and Three-Way Switch Install
post #17 of Old 05-23-2008
sailingdog
Yes, I usually call when I see just a mast sticking up out of the water.
Originally Posted by max-on View Post
Don't throw any bad vodoo at me SD! I do agree with you, it just needs an access port for convenience, the seacock is on the engine block behind the companionway.
Say the engine seacock hose is 1 inch OD, I do not think the pump could keep up anyways; hopefully someone would notice and make a call.
HEY, the two of you stay on topic, and stop arguing whose is bigger!
Another/next project is a solar panel. I have a plug on the stern as the PO used a windvane, and a switch in the boat. I do not know much about solar other than what I have read here; I do not think there is a controller though, which I think I would need, I also need a battery monitor.
Depending on the size of the solar panel, you may not need a controller... but that would be a maintenance charge level sized panel, rather than one that could recharge your battery banks. You probably want one that will re-charge your batteries as needed. An 80 Watt panel wouldn't be a bad fit. It'd replace about 30 amp-hours a day... and is about the minimum size panel that would require a charge controller on your boat.
For the battery monitor, get the Xantrex Link 20.
sailingdog is offline
