SailNet Community - View Single Post - Pump Float and Three-Way Switch Install
post #18 of Old 05-23-2008 Thread Starter
max-on
1997 Dehler 33
max-on's Avatar
Lifeline AGMs, SD, if I recall 105 amp/hrs. I am probably better off with the biggest pump that will fit the space and the current output hose, as if I ever 'need' the pump it will be because the boat is sinking, not because of a maintenance matter or casual use.
Thanks SD, that is one of the things on the list. I went for the assy spinnaker this year instead! Next, I need to look at the electronics, it all works, but I do not have wind speed, as the transducer is busted, I still have direction though, and as it is navico, I have not been able to find a replacement, I just go old skool.
max-on is offline
