SailNet Community - View Single Post - boom vang?
Thread: boom vang?
Old 05-24-2008
Jeff_H's Avatar
Jeff_H Jeff_H is online now
Super Moderator
I like Garhauer as well. A couple quick thoughts, the Mega has a proportionately high aspect ratio mainsail and so produces high leech loads. A working load of 2000 lbs is probably about right but I would go to a cascade with a single block on the boom and wire or spectra line through it to the working end of a 4:1 or even 6:1 purchase which should get you to the ability to adjust it under loads up to around 600 lbs.
I would not get a rigid vang if you plan to trailer your Mega as they get in the way when striking the rig.
