SailNet Community - View Single Post - what size outboard?
post #5 of Old 05-25-2008
ReefMagnet
Living the dream
ReefMagnet's Avatar
If, like me, you use your motor to get you home on schedule when the wind dies or is coming in on the nose, I would say go for the 9.9.
I've got a 4 stroke Yamaha 9.9 High Thrust on my 25 footer (about 2200kg). I purchased it second hand (one half of an ex catamaran setup) and have been really happy with it. At the time I was tossing up between the Tohatsu (Nissan), Honda and Yamaha and was actually just about to plonk the money down on a new Yammie when I came across this not too old used one. It replaced an 8 hp two stroke mariner.
A bit of Internet research made me favour the Yamaha High Thrust as it has both a good reputation and is designed especially for displacement speeds - even down to the extra reduction in the gearbox. The Honda has a high thrust prop option, but the gearbox is the same as the standard model. One thing I liked with the Honda is that it retains the pull starter whereas if you get a flat battery with the Yamaha, you have to remove screws to get a rope on the flywheel pulley to start it by hand. The Tohatsus are well priced and light weight but I know of people that have had some issues with corrosion of some mild steel components on them in moored / docked situations
Anyway, love the Yammie. Rarely need to run it at anything past 1/3rd to half throttle to get up to about 5kn+ on my boat, reverse works exceptionally well (something that didn't on the the old Mariner!). I don't normally use the motor in a blow, but I've used it to push against a 4knot current when I've been in a hurry and it'll push the boat well up onto the bow wave at near full throttle.
Fuel usage is about two litres an hour at 5 to 6 knots which is a lot better then the old two stroke it replaced.
ReefMagnet is offline
