Originally Posted by labatt
What's that law? The simplest answer is usually the right one? After disassembling half of our water system, playing with the pump and lugging an air compressor to our boat, we found the answer to our problem. Apparently we must have had some crud in the system and the faucet aerator screens were clogged up. Oh well, but at least we're back in business!
i think this is what you are referring to.
if you rule out the simple things first, your frustration level will go down somewhat.
if you have a filtration system, a dirty filter or being airlocked could explain the problem. however, never discount the possibility it could be something easily overlooked (clogged aerators for example). prepare for the major issues, like a bad
pump. budget boat units for project.
Hanlon's Razor: ``Never attribute to malice that which can be adequately explained by stupidity''.
