SailNet Community - View Single Post - The boat seems to be leaking water through the "tiller hole"...
post #1 of Old 05-26-2008 Thread Starter
First off, the boat is a 1972 Bristol 26, swing keel version
So on the way down the Hudson River from Kingston Sunday, we noticed that there was water leaking into the cockpit from the point where the "tiller base" (the part of the tiller assembly that is screwed to the floor of the cockpit) and the "spindle" (what I assume is a rod of some sort that is connected to the rudder).
We got the boat this spring (see "long island sound to hudson river cruise" thread) and are sure there has never been water leaking in before. We had a bungee cord wrapped around the tiller to keep the boat pointed in a steady direction, our "auto tiller"....and after we took the bungee off, the water stopped leaking a little while later. In total, there was about a half liter of water into the cockpit over the course of an hour or so.
I did some investigative work, and there is a "tube" (what looks like a fiberglass pipe that looks like it is molded into the bottom of the hull) that goes from the cockpit straight down through the bottom of the boat. This is where my "rudder spindle" goes through. There was no water leaking in this area at fact, it was dusty. Only several drops of water that I could tell were leaking in from above through the cockpit floor, where the "rudder spindle passes".
My conclusion:
moderate to heavy pressure downward on the tiller puts pressure onto whatever gasket is inside the "tiller tube".
whatever gasket is in there is probably pretty old and should be replaced at the next convenience
My questions:
Worry about it now, or don't worry about it until this fall when we take the boat out....or if it gets worse before then, deal with it then
Can I deal with such a thing while the boat is in the water? I could see why totally disconnecting the assembly would probably mean my rudder would fall to the bottom.
It looks like my cockpit floor is above the waterline....maybe thats a given.
whaddya think, paranoid...or "another something to add to the list"
martsmth is offline
