SailNet Community - View Single Post - electric trolling motors for small sailboats?
post #11 of Old 05-27-2008
tjaldur
tjaldur's Avatar
I use a 30 pound pushpower trolley (probably the smallest) on my inflatable dinghy. The consumption is about 230 watt. I use two 80 amp batteries. One in the dinghy, the other on board the ship for charging. One charge last for 4 hours use. For charging I use a 2,5 KW gas-generator.
If were not that I also need to use the generator for a whole lot of other charging purposes, like charging the batteries for use with refrigerator, TV, computers etc. I would probably spend more gasoline, make more noyce charging the batteries for the dinghy than i would using a small 5 -6 HP two-stroke for propulsion.
I believe you need to make an input/output calculation of the charge/use of current. It is the charging capacity that will define the distance of "the point of no return".
Use your head, ram the wall till it falls.
tjaldur is offline
