SailNet Community - View Single Post - 1982 Hunter '54
Thread: 1982 Hunter '54
Old 05-27-2008
sailingdog sailingdog is offline
Any 54' sailboat that goes for only $100,000 is going to be in need of some serious work or is a real piece of crap to begin with.
Do you have any idea what the costs associated with OWNING a 54' sailboat are going to be like? If not, might want to do a reality check on that first. Consider that the ownership costs pretty much double for every 10' of boat, so a 54' boat is likely to cost at least four or five times what a 30-35' boat would cost you, at a minimum. And that is if you do most, if not all, of the maintenance work yourself.
Also, Hunter doesn't have the best track record as a manufacturer, but the Cherubini models seem to have a better record than many other Hunters of that era.
From your OP, you seem to indicate that this would be your first cruising size boat... I would highly recommend that you start with something a bit more manageable. Making mistakes on a 54' boat will often involve forces that are large enough to kill you easily.
Finally, a 54' boat won't be an easy to manage cruiser. It will have far more complex systems than most boats 30-35' long, and there is far more maintenance to do on that size a boat.
