Old 05-27-2008
browncrew browncrew is offline
browncrew is on a distinguished road
Wink It's Always Better to Check with the Manufacturer
Wiring a Computerized or Rule-Mate Bilge Pump
Brown (Positive) wire will connect directly to the Automatic side of the panel switch or power supply, if the Brown wire is connected directly to power supply it needs to be properly fuse protected. The Black (Negative) wire will connect to the Negative battery terminal or Negative Buss bar." />>>
Wire the Bilge pump directly to power supply, this will ensure the pump has power if the power system on boat has been isolated.>>
>You'll get a lot of expert advice here, but I would always check the manufacturer's web site in the future.>
>Keith>
