Old 05-27-2008
knothead's Avatar
knothead knothead is offline
You can also end-for-end two single lines and get a bit more life out of them by spreading out where the chafe and wear occurs. Can't do that with a single line.
If you use a single line tied to the clew it can be cut into two pieces when it starts to wear and then end for ended.
I think that as others have said, if you are using a dedicated sheet then it makes sense to leave it one piece.
Ron Paul 2012
"wikijar"
