Flying a spinnaker single-handed
Not long after purchasing my 26 footer,I bought a used tri-radial spinnaker,a pole,and all the associated gear.I enjoyed using the sail,but as I began to sail my boat single-handed more often,it just wasn''t a very user friendly sail for the application.I bought a sock for the sail thinking that it would help.My intention was to add some rigging where I would be able to launch,fly,and douse the sail from the cockpit.I never accomplished the task for various reasons.I started looking at cruising spinnakers and ended up buying one from Lee sails about a year ago.I also bought something called a "tacker" that basically attaches around my furled genny,and then the clew of the spinnaker attaches to it.I took the sock off of the tri-radial to use with the cruising spinnaker.I hadn''t really used the sail much until yesterday. I have to tell you, I love this sail.For reaching,it''s great!For anything other than reaching, it just isn''t much pumpkin.(Southern term for not good) I had a blast playing around with it and found that it was very easy to jibe.Using the sock with the sail also makes it very easy to douse should things get dicey while out alone.I was wondering if there are any single handed sailors out there that fly spinnakers, and use similar gear that could help me with a few issues.(1)If you use the "tacker" how successful have you been using it with a assymetrical spinnaker.Do you use a regular pole with it,or just a whisker pole? How effective is the sail using it in this form for runs. What about rigging? If you''re using a sock,have you devised a way to launch and snuff the sail from the cockpit? I''ve thought about buying a sock for my tri-radial and possibly a whisker pole.If the tacker would work well with the tri-radial for runs,it would give me a good arsenal for pretty much all conditions while sailing single-handed.I know that for flying these types of sails,(especially racing)there are a lot more efficient ways.When you''re out there alone though,simpler is definitely better.Thanks for any help you can provide.
