SailNet Community - View Single Post - Adler Barbour Troubleshooting (LED Flash)
post #16 of Old 06-02-2008 Thread Starter
FortAwesomeIII's Avatar
OK, here's a progress report... The info at was incredibly valuable at determining my problem:
Looks like after testing the input voltage(OK, 12VDC or above), Fan(OK, will cause start abortion if drawing above 1 amp), and compressor(OK, the Danfoss unit should have the same resistance between all pins and have an open circuit between the pins and compressor body), it seems that the DB50 control module is faulty. From my limited research, It looks like the module is about $350. A new supercoldmachine is a little less than $800. I went ahead and ordered a new unit just to be sure everything will be operational. In my opinion, the compressor and the rest excepting the control module is good. If anyone has a unit with a bad compressor or other problem that could still have a good module, I would be interested in buying it.
Also, I ordered a 31Q Waeco Drawer fridge that I am going to install in an unused place to further increase my cold storage capacity. I have a 14Q Engel Deep Freeze that works great for meats, frozen drink mixes and such. I will use the drawer fridge for cheese, yogurt, or any other refrigerated food item, and I am going to use the existing fridge with the new Super Cold Machine for beverages only. I've got some starboard that I plan on dividing the fridge up with. Previously, I have had a LOT of room in the fridge but only a portion was usuable due to the layout. I'm planning on maximizing the room with the division.
Thanks everyone for the help!
John Pate
Highport Marina ZD27
aboard S/V Fort Awesome III
"I couldn't do the things the way those people do.
I couldn't live there if you paid me to. "
The Talking Heads
FortAwesomeIII is offline
