A lot of this is boat dependent, since each boat might be setup differently and require a different approach, even boats of the same make are sometimes setup differently.
There is also a big difference between being singlehanded and sailing with non-sailing guests, since even a non-sailor can hold a tiller and steer the boat in a straight
line if taught.
On my boat, I worry about the genny sheets, but ignore the main, since the main will generally take care of itself for the most part. I'll also use the
autopilot to tack the boat, since that allows me to use both hands for dealing with the two genny sheets.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
