Chances are good that the pencil zinc was probably protecting the heat exchanger for the cooling system. If it was missing for long, it is a bad thing... check it often, and replace when it gets down to about half it's original size.
Originally Posted by davidpm
We just replaced the pencil zinc in a Universal M25 Cat 30 that we just started working on.
The zinc was completly gone. No way of telling when it was replaced last. What damange should we be looking for?
The water injector fitting in the wet exhaust fell off. Is this collateral damage from the zinc? What else.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
