My portlights used to leak. I tried sealing them and that worked for a while. I'm currently refitting the boat for a Transatlantic voyage and have decided to place the portlights with lewmar opening portlights.
A little work is required to fit them in because of the Columbia shaped the cabin top to form the portlights. If you don't want to go through that, you disassemble the current portlights and install new plexiglass.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Columbia 9.6
Distant Horizon
