SailNet Community - View Single Post - Steering Cable Replacement
post #25 of Old 06-03-2008
radcat
radcat's Avatar
Thanks for the reply. The problem is that even if I bought cables from Edson, I would have the same issue. Replacement cables from them are the same as what I currently have- 3/16" wire with a swaged thimble on one end and thimbles/clips to install on the other end. The radial end can't be made up ahead of time because the thimbles won't fit through the bottom of the pedistal. Getting the operating length correct is no problem (I measured the old ones). The question is how much space do you really need between the two clips on each wire. According to some US Navy literature I found today, 6 cable diameters between clips should be OK. I think I can make that work.
radcat is offline
