SailNet Community - View Single Post - raw water pump leak on Yanmar 3Gm30F
post #4 of Old 06-05-2008
NOLAsailing
NOLAsailing's Avatar
There's not much to a water pump - it's belt driven and it spins a shaft connected to the impeller inside a housing. It's mechanically very simple. You should replace the impeller and the gasket at least once a year. Do this before you worry about replacing the whole pump. Be sure you get the old gasket completely off. If it's old, it will likely be well adhered to the water pump cover.
-Jason
NOLAsailing is offline
