SailNet Community - View Single Post - 1982 Hunter '54
Thread: 1982 Hunter '54
  #25 (permalink)
Old 06-05-2008
shasen shasen is offline
shasen is on a distinguished road
The Hunter 54
Hi Cayoosh,
You will find that the Hunter 54 is a very different boat than a typical Hunter. I've been tracking Hunter 54 prices for the last 10 years, they have took the normal dip in value after the 20 year mark. A yacht 20 in age is what most lenders will finance, so 20+ year yachts typically dip in value after that mark due to the buying pool becomes less. Historically H54's can be had from 120k-70k depending on condition.
The Hunter 54 was designed as an Ocean Racer. Some of the features that I like are its safety. It is a very fast boat and that makes it much more safer than a slower boat. It also has all of the other numbers/formulas as far as stability goes. Its boom only extends just shy of the companionway entrance, so there is zero chance of getting smacked in the head with the boom while in the cockpit or going below. All controls run into the cockpit. The Rudder placement as some have stated makes her a little weird in a following sea, that it makes her super maneuverable when docking.
All of that said, the Hunter 54 was built in 1981-1984 so that makes for a boat that could be full of issues due to age and corrosion as with any boat of that age. An old boat of that age will most likely need certain areas and systems to be updated/restored.
Again, checkout "hunter 54 dot com" for more info.
Stirling,
